2006 Honda Odyssey Location of theplug into which the trail
2006 HONDA ODYSSEY
BILLY R.
Electrical problem
2006 Honda Odyssey 6 cyl Front Wheel Drive Automatic
I am installing a trailor hitch. the owners manual states the plug socket is in the right rear compartment . I can't find it. Is it with a pigtail like previous models are is it part of a panel?
Feb 4, 2010 at 6:14 AM
RACEFAN966
  • 5,029 POSTS
First let me say thanks for asking this question. I find so many just start cutting and do damage to things doing so. Now first you need to get the T-connector. Drawtite number 118438. Then if you go to there web site and then go to t-connectors and then look up honda it will bring up a page with the part numbers for honda click on your vintage and then it will bring up the connector t-connector you need then you will see a pdf file labeled instullation instructions. This will show you step by step how to install the t-connector. Hope this helps. It is www.draw-tite.com/fitguides/pdf/N118438.pdf Here is pic of the t-connector.
https://images.2carpros.com/forum/automotive_pictures/249564_118438_1.gif
Feb 5, 2010 at 1:57 AM
