2006 Honda Odyssey gas shutting off early on fill-ups
2006 HONDA ODYSSEY
19,000 MILES • 6 CYL • FWD • AUTOMATIC
BRADAZ
I bought the van brand new. Ever since I have had it, the gas nozzle will cut-off early. However, I am still able to put an additional 4+ gallons in if I go about 20 cents at time and then it cuts off again and then I wait a few seconds and then it will take a bit more. It always happens and I can always put in about the same amount before it is really "full." I have taken it to my Honda dealer and they said it seems to be working ok. They said with this car the tank is very shallow and wide so it could happen a bit. I recently heard about evaporative system shut-off sytems that regulate the pressure in the tank and shut off the gas nozzle when the pressure builds up in the tank. I think that may be going on in my case, but am not sure. Can you advise?
Aug 23, 2008 at 6:51 AM
KHLOW2008
  • 41,814 POSTS
Hi bradaz,
It could be the Evap system but more likely to be the filler pipe check ball getting stuck or its relief hose kinked/clogged.
Aug 27, 2008 at 4:39 AM
