2006 Honda Odyssey Electrical problem
KBARROW
2006 Honda Odyssey 6 cyl Front Wheel Drive 75000 miles
3rd (upper rear) brake light turns on when lights are on. Backup lights won't work with lights on. Radio console lights turn on when brake pedal is pressed (with out lights turned on). When lights are on, 3rd brake light turns off when brake pedal is pressed, and so do tail lights, but rear brake lights seem to work.
Thank you for your time.
Feb 4, 2010 at 4:08 AM
KHLOW2008
  • 41,812 POSTS
Hi kbarrow,
If you had replaced any bulbs, recheck the bulb installation.
Check the ground circuit at the rear taillights for cleanliness and installation. A bad ground circuit connection would cause the symptoms described.
Feb 5, 2010 at 2:29 AM
