2005 Honda Odyssey Signal Light Stays on
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
REDRUGBYCAT
When I activate the signal light in either direction as soon as I apply the brakes the signal light stops flashing and the right signal light stays on until I release the brakes.
Jan 21, 2009 at 11:29 PM
MIKE H R
  • 3,094 POSTS
sounds like a broken wire or bad ground. Remove the bulbs and clean out the sockets first, then replace bulbs. That usually takes care of the problem. If it does not then check the wires to make sure nothing has shorted or crossed.
Jan 22, 2009 at 1:01 AM
