2005 Honda Odyssey Reapair on a 2005 Honda Odyesse EX
2005 HONDA ODYSSEY
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
MONTYP
I have a questions in regards to repoairing a harmonic balancer for a 2005 Honda Odyesse EX. What is the process to remove and install.
Thank you
Jul 19, 2009 at 3:25 AM
KHLOW2008
  • 41,814 POSTS
Hi montyp,
The harmonic balancer is incorporated into the crankpulley and has to replaced as an assy.
You would need to remove the drive belts and the central bolt ( torqued at 150 ft lbs so might not be easy remove it). The oully can be taken off after removal of the bolt.
Jul 22, 2009 at 5:45 AM
