2005 Honda Odyssey Interior Light Burned Out
2005 HONDA ODYSSEY
MOMMYOF2CUTIES
Electrical problem
2005 Honda Odyssey 6 cyl Automatic 115000 miles
My interior map light stopped working with the door open option, although you could still manually turn it on. Then a week ago, it quit working all together. I checked the bulb, replacing it with a new one and the other "working" one, and also checked the fuse which I found worked with the other map light. Light still does not work, could it be on a seperate fuse under the hood, or is there some other "easy" fix that I might try next?
Aug 16, 2010 at 4:37 PM
KHLOW2008
  • 41,814 POSTS
Hi mommyof2cuties,
There is no separate fuse.
Did you try opening all doors to check if it works when any particular door is opened?
Remove the maplight cover and test the light bulb socket for battery voltage with bulb removed. Note which terminal has battery voltage and reinstall the bulb. With the switch turned to door open mode, ground the terminal that does not have any voltage with the test lamp. If bulb or test lamp lights up, you have an open circuit between the light and door switches.
Aug 17, 2010 at 2:42 AM
HONDA TECH 1818
  • 536 POSTS
Check the door light switches on the door jams, the switch could be broken and fallen inside the pillar.
Aug 17, 2010 at 3:51 PM
