2005 Honda Odyssey Gas Struts at Rear Tailgate
2005 HONDA ODYSSEY
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
SATOTH2
How do you or where can I find intstructions with photos for replacing the gas struts that support the rear tailgate?
Aug 8, 2010 at 6:19 AM
KHLOW2008
  • 41,814 POSTS
Hi satoth2, Here are the instructons. TAILGATE SUPPORT STRUT REPLACEMENT 1.With the help of an assistant, use a flat-tip screwdriver (A) to pry the support strut clips (B) from each end of the support strut (C) at the tailgate and body, then release the support strut from the pivot bolts (D). Do not remove the clips from the support strut.
https://images.2carpros.com/forum/automotive_pictures/192750_RearSupportStrut05OdysseyFig03_1.jpg
2.Set the clips (A) to the original position, then reattach the support strut (B) on the pivot bolts (C) by pushing the support strut onto the pivot.
https://images.2carpros.com/forum/automotive_pictures/192750_RearSupportStrut05OdysseyFig04_1.jpg
Aug 8, 2010 at 7:43 AM
SATOTH2
Guys:
Thanks a lot for the response and instructions. This couldn't have been any easier. Start to finish, 9 minutes to replace the support struts. I'll be recomending you to my friends. Thanks again, Steve T ;)
Aug 13, 2010 at 5:28 AM
KHLOW2008
  • 41,814 POSTS
You're welcome Steve and thank you for the input.
Have a nice day.
Aug 13, 2010 at 5:55 AM
