2005 Honda Odyssey catalytic converter
2005 HONDA ODYSSEY
102,500 MILES • 6 CYL • FWD • AUTOMATIC
TANMAN0421
I had repair done on my van in January of this year and they replaced the timing belt and replaced the head on the engine because we were not getting any compression in cylinder #2. Now the car will not start and they say that the catalytic converter caused the timing belt and engine to blow up and we need a new engine. Is this possible for the engine to blow up just because of a bad catalytic converter?
Aug 16, 2010 at 12:12 PM
WRENCHTECH
  • 20,761 POSTS
No, I wouldn't believe that at all. A Catalytic Converter is not going to cause a timing belt failure. Poor maintenance and not replacing the belt when recommended will cause that but it looks like you were right on time with that one. Assuming no one previously worked in the timing belt area, I don't see a reason for failure.
Aug 16, 2010 at 12:42 PM
KHLOW2008
  • 41,814 POSTS
What really happened to the engine?
Did the timing belt broke and was the engine fault related to the timing belt?
Was it due to lubrication faults?
I concur with Wrenchtech about the catalytic converter not being the cause even if it is any of the problem I mentioned above.
Were the repairs done at a dealer?
Was replacement of head before or after the timing belt replacement?
Aug 17, 2010 at 1:37 AM
TANMAN0421
the timing belt caused the engine to basically blow up. We had the head work done at the same time as the timing belt being replaced. The work was not done at a dealer but a local mechanics workshop. I think all of the problems occurred due to shoddy work done the first time. We had the new engine and everything installed by a Honda Dealership.
Aug 18, 2010 at 9:05 AM
KHLOW2008
  • 41,814 POSTS
Yes, I would agree workmanship error is most likely to be the cause. Too bad it occurred after a period of use so it is not easy to get the workshop to take any responsibility.
Aug 19, 2010 at 12:05 AM
