2004 Honda Odyssey Vibration at various speeds
62,000 MILES • 6 CYL • FWD • AUTOMATIC
GIZMO0706
I have an "04" Odessey that has a vibration problem. It started out with a mild but annoying vibration at highway speeds. I had the tires (new goodyears) balanced with no improvment. I then had the tires rebalanced and rotated at a different shop. Now the vibration comes at different speeds (30-40 and over 70mph) and makes the steering wheel shake at lower speeds. What should I have checked next? I thought possibly a bad wheel or tire.
thanks
Dec 1, 2008 at 8:52 AM
F4I_GUY
  • 3,302 POSTS
Were they just checked for a dynamic imbalance or were they roadforce balanced? Roadforce balancing means the balancer actually checks if the tire is at fault (which you most likely will find).
I would take it to a GOOD tire shop, they most likely will find either you have a bent rim or a bad tire(s).
If after the tire rotation, you noticed a difference then you have pretty much confirmed it is within the wheel itself and the rest of your suspension is fine.
Dec 2, 2008 at 9:22 AM
