2004 Honda Odyssey Security System
HORNUNGB
Electrical problem
2004 Honda Odyssey
Our Honda security system went off in the middle of the night with no apparent reason. The doors were locked.
After resetting the system 3 times and then finally driving it, it appeared to be ok.
Again tonight it went off again - do you know why this is happening?
Jun 26, 2008 at 3:21 PM
KHLOW2008
  • 41,812 POSTS
Hi hornungb,
Did you get any room light blinking while driving?
High possibility is one of the switches is not closing properly and when vibration occurs, it contacts and sets off the alarm.
Check for out of flush doors, bonnet and rear door. Check if any switch rubber cover is worn, torn or dislodged.
Jun 28, 2008 at 3:30 AM
