Rear Window Vents
54,000 MILES • 6 CYL • FWD • AUTOMATIC
HSARGENT
Both stopped working. The right is partially open. I do hear a relay sound when I engage the switch. The On/Off on the door is on.
The manuals says the motors have a circuit breaker. There is a reset procedure in the manual which does not help. I found some 7.5 Amp fuses in the Driver's side fuse box. They seem both to be okay.
Sep 23, 2008 at 8:46 AM
2CARPRO JACK
  • 11,533 POSTS
Need to check fuses 7,8 15,16. If allok, there are open and close relays for both windows. You will need to find them(behind left and right rear trim panels) verify red/white wires haev power to the relays.If so tets the motors to see if they are getting power to open , then close
Sep 26, 2008 at 1:34 AM
HSARGENT
I did check fuses. I hear relays near the vents. One vent does respond some but not all the time and all the way. Which panel exposes the motors? My book did not show.
Sep 26, 2008 at 9:54 AM
2CARPRO JACK
  • 11,533 POSTS
Mitchell doesnt specify either... just says r/l rear trim panels. I would suspect it to be the ones directly under/behind the windows. Once you get tot eh relays, test for the trigger when trying to open/close them, this will tell if it is a relay, motor or switch problem
Sep 26, 2008 at 11:00 AM
DANPRITTS
i'm not sure this will help you, but this page was a high google hit for "odyssey window fuse", so maybe it will help the next guy who comes looking.
My haynes manual instructs that the 03 & 04 models might require a power window control unit reset when the battery is disconnected or other power loss (e.g., pulled window fuse or disconnected wiring to window controls).
- turn ignition off
- turn ignition on
- fully open driver window by pressing auto down; when it opens the whole way, hold auto down for 2 seconds.
- fully close driver window by pulling up; when it is closed the whole way, hold up for 2 seconds
- if it still doesn't work repeat the procedure
Jan 19, 2009 at 3:25 AM
RAFAELN
Hello there,
My two rear windows don't open. when i push the button i can hear the sound trying to open but they don't. i've tryed pulling/pushing but it don't seem to help. can i resolve this or i need to take it to a electrical place?
thanks in advance!!
Jun 10, 2019 at 11:48 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi RAFAELN,
If you hear the motor running but the glass are notmoving up or down, the regulators are bad and you need to send it to a mechanic, not the electrician.
RAFAELN
Thanks for the prompt reply, but it is not the glass going up or down, i'm having issues with the two back windows/flaps that open in and out.
thank you!
KHLOW2008
  • 41,812 POSTS
Sorry for the mistake. Since motors are running, it could be a fault with the linkages and is not an electrical fault. To check the linkages, you would have to remove the trims.
RAFAELN
no problem and excuse my ignorance, but after i remove the trims, what would be the next step, what will i need to inspect directly?
thank you very much you guys are great!!
rafael.
KHLOW2008
  • 41,812 POSTS
After removing the trims, operate the motor and see if anything is out of the ordinary.
Ensure the windows are not stuck due to inactivity for prolonged periods. While operating the window switch, get someone to manually push the glass to assist the motor to see if it works.
