Passenger side window will not roll down
SNTS545
My window regulator went out a couple weeks ago, an i had to replace it but after everything was done and plugged in the window would only roll up but not down. I think it might be the wiring but not sure.
Oct 27, 2010 at 6:33 AM
KHLOW2008
  • 41,812 POSTS
Hi Snts545,
More likely to be the switch rather than anything else as the window can move in one direction but not the other.
This video will walk you through the steps on a similar car the process is the same.
https://youtu.be/Wp7Ak9IGs4o
Mar 11, 2019 at 10:12 AM
SNTS545
Its the passenger side window, and it wont roll down with either switch.
Thanks
KHLOW2008
  • 41,812 POSTS
Start by testing the passenger window switch first. PASSENGER'S WINDOW SWITCH TEST 1. Remove the front passenger's switch from front passenger's door panel
https://images.2carpros.com/forum/automotive_pictures/192750_PassengerWindowSwitch04OdysseyFig41_1.jpg
2. Check for continuity between the terminals in each switch position according to the table.
https://images.2carpros.com/forum/automotive_pictures/192750_PassengerWindowSwitch04OdysseyFig42_1.jpg
3. If the continuity is n ot as specified, replace the switch.
SNTS545
Thanks il do that and let you know how it goes.
GATORBAIT96
I replaced to passenger side window regulator on my '03 Odyssey and for some reason, only the up direction is working. When I try to roll it down, nothing happens-no sound, motion, or anything. I do not think the motor is receiving power when trying to roll window down. The window is all the way up and I can hear a clicking noise when trying to roll it up further. I have reset the window control unit using the instructions posted in this forum as well and it does not correct the problem. I'm starting to get really frustrated, can you please help?
thanks.
Jun 26, 2020 at 5:39 AM (Merged)
HONDA TECH 1818
  • 536 POSTS
I think there's a problem with the passenger side
mutiplex, I would replace the mutiplex in the passenger side fuse box.
GATORBAIT96
[quote:4f94166189="kng1818"]I think there's a problem with the passenger side
mutiplex, I would replace the mutiplex in the passenger side fuse box.[/quote:4f94166189]
Is this the fuse box in the passenger side footwell? How much does the multiplex cost?
Thanks.
HONDA TECH 1818
  • 536 POSTS
Yes, the passenger side mutiplex is in the right side fuse box at the foot well. It cost about $127.00 online.
JOHNNYCASH1
My passenger side power window regulator needed to be replaced. I purchased a new one and installed it. The window only goes up from drivers side master control. The window does not go down from either drivers side or passengers side switches. I originally thought the first regulator motor was defective,took it back to the store and reistalled another regulator and motor. I still have the same problem. HELP!
DOCFIXIT
  • 18,828 POSTS
Suspect faulty master switch ie. drivers side. Do you have a volt /ohm meter or a test light?
