2004 Honda Odyssey Noisy
DRISC8
Brakes problem
2004 Honda Odyssey Front Wheel Drive Automatic 117000 miles
when I drive slow I can hear in the rear, its sounds like something is rubbing, then when I hit the brakes it grinds like I need need brakes. HOWEVER, sometimes there is no grind at all. If I needed brakes wouldnt it grind all the time?
Sep 2, 2009 at 2:14 AM
KHLOW2008
  • 41,812 POSTS
Hi drisc8,
If the pads are almost worn, it sometimes would result in the symptoms described.
I would suggest checking them out to prevent damage to the rotor when the pads runs out.
Sep 4, 2009 at 5:50 AM
