2004 Honda Odyssey Engine Sputters & Lags
2004 HONDA ODYSSEY
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
EPESCHEL
I'm not sure if sputters/lags is the right wording. My Odyssey will make like a clicking noise briefly at times while driving. It tends to happen when light pressure is on the accelerator to maintain speeds and normally only happens at like 25 MPH, 35 MPH. If you accelerate quickly, the noise/problem does not happen. The RPMs get "stuck" so to speak and you have to let off the accelerator to get rid of the problem and then can push down on the accelerator again. It does not always happen. It seems that the speed you are going and the pressure on the accelerator makes a difference in whether or not it occurs.
Jun 23, 2010 at 5:12 AM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 23, 2010 at 2:52 PM
EPESCHEL
Thanks for the info. Is there an easy way to test those things? I am not a mechanic so how would I inspect and test to see if they are working? Or do I have to take them somewhere?
Jun 24, 2010 at 2:07 AM
You need to bring it in to a reputable shop and have them troubshoot it
Jun 24, 2010 at 8:26 AM
