2004 Honda Odyssey center console between two front seats
2004 HONDA ODYSSEY
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEWDININNY
I want to replace the sponge on my cup holders.
I am unable to get the top piece off. The piece underneath the top piece has 2 screws holding it
I can spread the top piece but it will not snap loose
HELP
Sep 16, 2009 at 12:59 PM
KHLOW2008
  • 41,814 POSTS
Hi lewdininny, Here are the procedures, let me know you are at which point. BEVERAGE HOLDER BASE REMOVAL/INSTALLATION NOTE: "¢ Take care not to scratch the dashboard and related parts "¢ Put on gloves to protect your hands. 1 . Make sure you have the anti -theft codes for the radio and the navigation system, then write down the frequencies for the preset buttons. 2 . Remove these items: "¢ Center lower console. "¢ Center panel "¢ Audio unit "¢ Display unit (with navigation system) 3 . Remove the beverage holder base (A). â—¦ 1 Detach the hook (B) from under the beverage holder (C). â—¦ 2 Pull the beverage holder out. â—¦ 3 Remove the screws (D, E). â—¦ 4 Remove the beverage holder base from the center lower console opening.
https://images.2carpros.com/forum/automotive_pictures/192750_BeverageHolder04OdysseyFig31_1.jpg
4 . Install the beverage holder base in the reverse order of removal, and enter the anti -theft code for the radio and the navigation system, then enter the customer's radio station presets.
Sep 19, 2009 at 6:12 AM
SAMBAL BADJAK
  • 20 POSTS
The console between the front seats is sandwiched together and the two parts are held in place by several Phillips head screws. I have gotten to them all by laying on the passenger floor and contorting my arm underneath the folding console to get at them. You will need a #2 Phillips - most likely a regular and a stubby one. They do NOT snap apart.
Sep 29, 2009 at 6:06 AM
