2004 Honda Odyssey Cabin air filter location and removal
2004 HONDA ODYSSEY
39,000 MILES • 6 CYL • FWD • AUTOMATIC
EECHAT
Honda Odyssey 2004. How to locate the cabin air filter and reolace it.
Thanks
Jan 14, 2010 at 3:26 AM
Dust and Pollen Filter Replacement The dust and pollen filter should be replaced every 30,000 miles (48,000 km) or 24 months whichever comes first. Replace the filter more often if the airflow is less than usual. 1.Remove the glove box.
https://images.2carpros.com/forum/automotive_pictures/12900_caf1_1.gif
2.Cut the plastic cross brace in the glove box opening with diagonal cutters in the area shown, and discard it.
https://images.2carpros.com/forum/automotive_pictures/12900_caf2_1.gif
3.Remove the bolts, the screws and the glove box frame.
https://images.2carpros.com/forum/automotive_pictures/12900_caf3_1.gif
4.Remove the filter lid (A) from the evaporator, then pull out the dust and pollen filter (B). 5.Install the filter in the reverse order of removal. Make sure that there is no air leaking out of the evaporator. 6.Install the glove box frame and glove box in the reverse order of removal.
Jan 15, 2010 at 4:29 PM
