2004 Honda Odyssey accessory plug and radio
144,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALYSON TANNER
During a road trip in Texas my accessory plug and radio both stopped working. I found the accessory plug fuse blown and replaced it. That did not fix the problem with the accessory plug. The radio fuse was ok.
Aug 23, 2010 at 3:21 AM
KHLOW2008
  • 41,812 POSTS
Hi Alyson,
If the fuse blows again, unplug all accessories and retest. Some accessories would cause the fuse to blow when they are not seated correctly or are bad.
Check the # 8 ( 7.5 A ) fuse in driver side underdash fuse box.
Check the Acccessory power socket relay in passenger side underdash fuse box.
Aug 23, 2010 at 5:18 AM
