2003 Honda Odyssey removing rear rotors
85,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVE ADAMS
What holds on the rear rotors ? Is it the #3 phillips screws?
Jul 14, 2009 at 10:44 PM
KHLOW2008
  • 41,812 POSTS
Hi dave adams,
Yes, the 2 screws are the ones holding the rotor. However the rotor is seated rather tight fitting with the hub and for removal, you would need 2 pcs of 8 x 1.25 x 12 mm bolt to slowly tighten into the existing holes to remove the rotor. turn each screw 2 turns at a time to avoid warpage.
Mar 1, 2021 at 5:44 AM
