2003 Honda Odyssey IGNITION
2003 HONDA ODYSSEY
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKEPAK
After replacing transmission and master cylinder recently at a dealer, my two other keys don't ignite my van. It shuts off right away after ignition. Oniy a key used when replacing transmission is working.
I don't know what is wrong. After repair, steering wheel is not firm. It rattles when I slow down to stop on bumpy road and audio control on wheel is malfunctioning.
Nov 12, 2009 at 4:23 AM
HONDA TECH 1818
  • 536 POSTS
Did they replace the ECM? If they did probaly they just program the key you gave to them. Is the steering wheel off center? They need to do an alignment after replacement of the trans. because they have to remove the front subframe and sometimes that would throw off the front toes.
For the audio control not working is the cruise control not working also?
Nov 15, 2009 at 6:39 AM
