2003 Honda Odyssey Gear Shift Lever Resistance
120,000 MILES • 6 CYL • FWD • AUTOMATIC
BUCK1195
Now when you shift into D, it takes very little effort to change gears. You can go from park to low in a flash. If you stop at each gear, the gear is selected. No slipping. Is this signs of an impending failure or just an annoyance of now a lower resistance changing gears?
Sep 23, 2008 at 4:43 AM
KHLOW2008
  • 41,812 POSTS
Hi buck1195,
When gears are selected, they would be engaged with minimal pressure, slight resistance felt.
If the idling speed is high, it would try to force the vehicle to move.
Oct 10, 2008 at 11:10 AM
