2003 Honda Odyssey catalytic converter
67,800 MILES • 6 CYL • 4WD • AUTOMATIC
SHANO
I took my car to the dealer b/c a mechanic told me it might need a new catalytic converter, which would be covered under warranty. The dealer said the cat is fine, but it needs a new B-pipe, which costs over $500 (p&l), and is NOT covered under the warranty. So, what is the B-pipe, and how do you tell if it needs to be replaced? Also, how can you tell if the cat needs to be replaced? (My car had passed inspection a few months ago and has no symptoms of problems.)
Dec 17, 2007 at 5:35 AM
  • 75,988 POSTS
Get a gas analysis done before and after the catalytic converter this will tell if the converter is doing its job. As for the pipe do you hear an exhaust leak? Its a 2003 I don't think its collapse inside the pipe causing problems
Dec 17, 2007 at 5:45 AM
MERLIN2021
  • 17,250 POSTS
Two ways to check for a bad converter, most reliable way is backpressure test, the 02 sesnor is removed, backpressure gauge is inserted and a reading is taken, you can however rap on it with a rubber mallet, see if anything rattlles inside! The B pipe is probably the one just behind the cat, if it has even a small hole, the emmissions test will detect it...
Dec 17, 2007 at 5:47 AM
