Hi, Car engine start good but I can not shift the gear with out unlock the gear
Oct 4, 2008 at 12:24 AM
KHLOW2008
✓ASE Certified Mechanic
Hi moezaung1,
The interlock is malfunctioning and most of the time the cause is the brake switch of fuse.
Check if the brake lights are working. If no, you should check the brake fuse and/or bpedal switch.
You can use the emergrncy shift lock to get it out of park by inserting the ignition key into the lock slot near the gear shift.
Oct 11, 2008 at 4:23 PM
