2002 Honda Odyssey Transmission
2002 HONDA ODYSSEY
115,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVID442
2002 Honda Odyssey, mileage 115,000. The orange engine light and the TCS light. The green drive light is flashing. The van doesn't move in drive. Will barely move in D3 or Reverse. It will move in second & low. The transmission fluid checks over full. I don't know if this is okay after driving for a while. I know the transmission is most likely messed up but don't know how bad. Any help would be great.
Thank you
David
Apr 17, 2009 at 1:31 PM
CAMARO1990
IM HAVING SAME PROBLEM, DID U EVER FIND THE SOLUTION ? PLEASE LET ME KNOW @ GUS@REGALLAKELAND.COM THANK YOU.
Oct 7, 2009 at 10:25 AM
AJVANDYKE
  • 36 POSTS
Based on your comments it sounds like either your torque converter or your transmission pump or both has completely failed. Those are the two main components in your transmission that create the nessesary line presure to apply the clutches. Resulting in little or no movement at the higher rpms.
Unfortunantly the only way to fix your problem is to overhaul your transmission. Odysseys are great vans but the tranny overhaul for one of those will cost anywhere from $2000-and up. Best of luck to you.
Oct 15, 2009 at 5:03 AM
