Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Odyssey
Ignition
Spark Plug
Replace/Remove
2002 Honda Odyssey Spark Plugs
2002 HONDA ODYSSEY
142,000 MILES • 6 CYL • FWD • AUTOMATIC
REYNOLDSDD
MEMBER
1 POST
How often do you need to change the spark plugs. Where can I find a maintenance guide to tell me what needs to be done when?
Sep 29, 2008 at 8:45 AM
KHLOW2008
Experienced Mechanic
Hi reynoldsdd,
Spark plugs replacement depends on the usage and type used.
Normal plugs should last between 10 to 15 k miles. If it is the platinum type, it can last up to 60k miles.
The maintenance schedule is found in the owners manual and if you don't have t, you can try getting it from Honda.
Oct 11, 2008 at 8:25 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
