2002 Honda Odyssey Spark plug replacement
91,500 MILES • 6 CYL • 2WD • AUTOMATIC
KIRANMR28
I recently had the 90K service done on my 2002 honda odyssey. It incl spark plug replacement. When I got back my car, I was chrged a extra hour of labor for spark plu replacement. When questioned, I was told that this is because the coil packs were individually wrapped around each spark plug and that they had to be removed before changing the plugs.
My question to you is ... Is this a typical arrangment in all odyssey Vans of 2002 with V6 engine? I want to understand whether this should have been covered in the standard work time or is it really diff in my van for which I had to be charged more than the normal service package rate quoted.
Thanks,
Kiran
Jan 5, 2009 at 4:22 AM
HONDATECH74
  • 34 POSTS
[quote:5a4206b9a6="kiranmr28"]Electrical problem
2002 Honda Odyssey 6 cyl Two Wheel Drive Automatic 91500 miles
Thanks,
Kiran[/quote:5a4206b9a6]all of the 2002 odyssey's have coil packs on each spark plug.
Feb 27, 2009 at 12:43 PM
