2002 Honda Odyssey poor gas mileage
77,000 MILES • 6 CYL • FWD • AUTOMATIC
SUNNYSANDY
I had a new transmission put in at 66000 miles and I am getting very poor mileage. 16 miles to the gallon around town. I used to get 19-20! What could be the problem? I tried inflating my tires more but that didn't help. I have had lots of problems with this car.We put a new air filter on and we change the oil at the right times.The Wiring burned up at 5000 miles. Gas tank gasket twisted and gas flooded the under parts of the flooring. 2 dead batteries. The warranty is over now so I would like to try and fix the rest myself. This is my first and last" new" car. I had the strutts replaced on both sides in the front as well.Thanks for your help. Sandy
Oct 10, 2008 at 6:29 AM
DOCFIXIT
  • 18,828 POSTS
Hi sunnysandy
Plugs recent,fuel filter throttle body been serviced also has timming belt been replaced. Try a good fuel system cleaner and you can have a computer scan done to see if all fuel control sensors are in range.
With an 8% drop probably not one thing just a combination of miles and years.
Good Luck
Thanks for donation
Oct 10, 2008 at 6:47 AM
