2002 Honda Odyssey Low beam headlight
81,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZINGER74
My low beam headlight on the passenger side of the vehicle went out. I replaced with proper bulb. Low beam is still out but high beam works.
Is this a fuse issue?
Thanks so much,
Chris
Dec 9, 2009 at 1:17 PM
KHLOW2008
  • 41,812 POSTS
Hi Chris,
The high and low beams shares the same fuse so it should not be a fuse problem.
Is your vehicle equipped with Daytime Running Lights?
Did you confirm the bulb is not faulty?
Dec 9, 2009 at 9:45 PM
