2002 Honda Odyssey Instrument panel lights
2002 HONDA ODYSSEY
120,000 MILES • 6 CYL • FWD • AUTOMATIC
LUNCHLADY01
Half my panel lights are out, checked the instrument panel fuses, fine. Anything else I should check?
Aug 29, 2009 at 5:46 AM
KHLOW2008
  • 41,814 POSTS
Hi lunchlady01,
As part of the panel lightings are working, it rules out a fuse as the system is working. The most likely cuse would be bad bulbs. You would have to remove the instrument cluster to replace the bulbs.
Aug 30, 2009 at 8:42 PM
