Hi Jbaird,
I do not know if the model you have are tthe same as wht we have here.
If the meter cluster cover panel leads to the centre, then you need to remove it first by removing the 2 screws at the upper end.
Pul cover loose, they are attached with some spring clips at centre.
You can then access the screws holding the AC control.
SPONSORED LINKS
Saturday, June 14th, 2008 AT 10:20 AM
