2002 Honda Odyssey Headlights
2002 HONDA ODYSSEY
122,000 MILES • 6 CYL • FWD • AUTOMATIC
FLYBOY8584
Why does my headlight go out when I put on my high-beams, I tried to put the one that does work into the one that doesn't and it still goes out. Any experts out there that could help?
Mar 6, 2010 at 7:22 AM
KHLOW2008
  • 41,814 POSTS
Hi flyboy8584,
Which high beam is not working?
Is vehicle equipped with Daytime Running Lights?
Mar 9, 2010 at 4:33 AM
FLYBOY8584
Its the passenger side headlight and it does have DRL which the light on the dash has been on for a while, changed the lights out, but still happening.
Mar 9, 2010 at 8:50 PM
KHLOW2008
  • 41,814 POSTS
Check fuse # 43 ( 15 A) in underhood fuse box for battery voltage when headlights are turned on to high beam. If battery voltage is not available, check the headlight relay # 1.
Mar 10, 2010 at 9:53 PM
