2002 Honda Odyssey gas mileage drop
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADIAZ
I own a honda odyssey 2002 with 120000 miles and two months ago I noticed the fuel efficiency dropped a lot. Tire pressure is @ 38 PSI and not leaking, gas does not seem to be leacking either. Can someone tell me what are the most probable causes to look for?
Sep 29, 2008 at 12:11 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:6d22e24bf1="adiaz"]Engine Performance problem
2002 Honda Odyssey 6 cyl Two Wheel Drive Automatic 120000 miles
I own a honda odyssey 2002 with 120000 miles and two months ago I noticed the fuel efficiency dropped a lot. Tire pressure is @ 38 PSI and not leaking, gas does not seem to be leacking either. Can someone tell me what are the most probable causes to look for?[/quote:6d22e24bf1]
When was your last tune up? Last air filter change fuel filter.....
Is your check engine light on? if so have codes pulled, your local auto zone will do it free.
Post findings here in forum....
Sep 29, 2008 at 12:26 PM
