2002 Honda Odyssey Front wheel hub nut
165,000 MILES • 6 CYL • FWD • AUTOMATIC
BISHOP57
I broke the 1 lug when trying to remove front right lug nuts.
There is no opening or room to fully punch out
lug. The back of the hub has a area close and raised and will not allow you to punch the lug thru. The spindle nut is 36mm. Is this the only way I have or is there another solution? If i have to remove spindle nut how do i stop the front hub from moving as i turn the nut. Can you tell me what the torque is on the nut.
May 21, 2010 at 9:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the spindle nut tightens to 181 Ft. Lbs. and yes it is the only way to replace the lug studs. just break the nut loose before raising the vehicle up, then finish removing it after raising vehicle..
May 21, 2010 at 1:11 PM
