2002 Honda Odyssey engine shots off
122,000 MILES • 6 CYL • FWD • AUTOMATIC
KOS965098
hey hope some one can help me..!!! my car cant stay on..when i crank the car have to gas it up alot for it to start...second when i try to remove the car from park to drive it shuts off...just got the transmission done for the 3rd time lastweek..!!! the transmission place said that there is 3 other dtcs still in the system p0505,p0132 and p0141...can this codes be the problem or is it something else..? trying to see if i can fix asap
Sep 30, 2010 at 3:15 AM
HONDA TECH 1818
  • 536 POSTS
DTC P0505 is the idle control system malfunction.
A bad IAC valve causes P0505 and causes not to idle.
DTC P0132 Primary heated oxygen sensor circuit high voltage.
Could be disconnected or faulty primary 02 sensor.
DTC P0141 Secondary heated oxygen sensor heater circuit malfunction
Faulty secondary 02 sensor.
Oct 17, 2010 at 6:44 AM
