2002 Honda Odyssey
170,000 MILES • 6 CYL • FWD • AUTOMATIC
CHETVSHAH
Code say P0730. Apart from replacing trasmission, any suggestions. It has slight erratic shifting, and specially, at times, gets stuck in 2nd gear, I have to shift to neutral, then back to drive then its ok
Thanks
Nov 24, 2009 at 8:21 AM
KHLOW2008
  • 41,812 POSTS
Hi chetvshah,
Thank you for the donation.
Before replacement of the trans, the shift solenoids, PCM and wiring should be checked for fault.
This is quite a common fault and there is an extended warranty for the transmission but your mileage is out of the warranty range so guess you are not able to get it replaced/repaired under warranty.
Nov 24, 2009 at 9:58 AM
