2002 Honda Odyssey
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
EBARBAROTTO
the fan for a/c only will only work when set to auto, but onlycomes on high. can also set to high manually but there is a delay and then it may come on high only. have had some parts changed but am being told it is the blower motor relay. i purchased this part but can't find where it is located. what also puzzles me is that the rear fan works fine but not the front but yet the a/c will not come on at all. could this be a 2 part problem or will the compressor not come on if the fan doesn't work? but the rear fan does work.
Aug 30, 2008 at 3:58 AM
CGACC
Just experienced this exact problem tonight...
76k miles, Did you get it fixed? What was the cause?
Sep 21, 2008 at 3:21 PM
