2002 Honda Odyssey
74,000 MILES • 6 CYL • FWD • AUTOMATIC
POGI
engine and tcs lights are on also when put in gear reverse or drive ''D'' start flashing sometimes jerks took it to a dealer did a diagnostic test and came up with a code P 1705 but they're not sure which sensor because of the after market alarm that i had hooked up 2 years ago.my question is if removed that alarm will the lights go off.thanks
Aug 13, 2008 at 3:54 AM
KHLOW2008
  • 41,812 POSTS
Hi POGI,
The problem is a shorting issue, so if the alarm is interfering then removing would solve the problem.
Disconnect the system and see if the problem is solved. If not, we will get to more detailed analysis and testing.
Aug 16, 2008 at 6:04 AM
