2001 Honda Odyssey Vehicle shakes at speed
SHOTGUN1958
  • 7 POSTS
Shakes or Wobbles problem
2001 Honda Odyssey 6 cyl Front Wheel Drive 141000 miles
My minivan shakes when on the freeway going over 50 mph. If I back off the accelerator the vehicle rolls smoothly. No vibration comes up through the steering wheel, it appears to come from the engine. I have changed the ERG valve. The car has never had a tune up. Check engine light is on. On occasion the TCS light comes on. Had transmission rebuilt about 6 months ago. TCS light problem was happening before trans was rebuilt. I purchased the car used (with 40K on the odometer) I asked the local honda dealer if the EGR fix had been performed (installation of a tube in the intake manifold) they told me it had already been done on my vehicle.
Any suggestions?
Mar 29, 2009 at 11:47 AM
ZACKMAN
  • 4,202 POSTS
Let's start by checking the check engine light. Take the vehicle to Autozone and have them scan the computer for free. Post the code NUMBER(S) here. It would also help if you perform the required tuneup. 140K miles is a long time without proper maintenance.
Mar 29, 2009 at 12:11 PM
SHOTGUN1958
  • 7 POSTS
Good idea, BUT- I can't find any info on performing the tune up except changing the spark plugs! I've searched the internet for over an hour and looked in my Chilton's manual. Spark plugs, air filter - that's about it.
Suggestions?
Mar 29, 2009 at 2:16 PM
ZACKMAN
  • 4,202 POSTS
While that is true (to some degree), spark plug is the only ignition part to replace. You still should replace your PCV valve, clean the throttle body of carbon build-up, add some fuel injector cleaner into the gas tank, replace the cabin air filter and
https://images.2carpros.com/forum/automotive_pictures/55316_01odesseytuneup_1.jpg
You still need to go to Autozone for the scan for the check engine light.
Mar 30, 2009 at 2:30 PM
SHOTGUN1958
  • 7 POSTS
got two codes
Po420 - Catalyst Efficiency below threshold, bank 1 and
Po401 - EGR Flow insufficient.
I just replaced the EGR valve about a week ago.
I"m putting in new plugs this afternoon.
It shakes only under load, ie, up hills or during acceleration. Sometimes the TCS light is on, sometimes it's not.
RPMs don't seem to matter. 2,000 rpm at 65 up a slight hill and it shakes. 2,000 in D3 going about 45 up a hill and no shake.
Could it be the transaxles? Had balancing and alignment done last week.
ALSO - called local Honda dealer and the assured me that the EGR "pipe fix" had been completed on my car, although they could not tell me when.
Very confusing.
Apr 5, 2009 at 8:57 AM
ZACKMAN
  • 4,202 POSTS
MIL IS ON WITH DTC P0420
TECHNICAL SERVICE BULLETIN
The MIL is on, and DTC P0420 (catalyst system efficiency below threshold) is stored.
PROBABLE CAUSE
The catalytic converter has deteriorated.
CORRECTIVE ACTION
Replace the catalytic converter, and check for any related DTCs.
PARTS INFORMATION
Catalytic Converter:
Odyssey (all): P/N 18160-P8F-J00, H/C 6148746
As for P0401, you may wish to call a different dealership and ask them the same question. While reading the TSB, I noticed that even if the repairs were completed, there is a chance that the pipe is clogged, causing EGR insufficient flow.
Apr 5, 2009 at 4:18 PM
SHOTGUN1958
  • 7 POSTS
Would a bad catalytic converter cause the shaking? Why?
Apr 6, 2009 at 7:25 AM
ZACKMAN
  • 4,202 POSTS
Usually bad cat is plugged up. As such, the exhaust gas has nowhere to go but back into the engine, creating enormous amount of negative pressure in the system. Because of this, your engine will lose power battling the pressure and as a result you will feel the shaking.
Apr 7, 2009 at 3:19 PM
SHOTGUN1958
  • 7 POSTS
That's it! Took it to the dealer and had the intake removed and a passageway unplugged. It's a fairly common problem with these cars.
Thanks for your help!
Apr 17, 2009 at 11:22 PM
SHOTGUN1958
  • 7 POSTS
I spoke to soon! The problem is not fixed. My odyssey still shakes above 40 mph, but only after it has been running more than 20 minutes or so. If it is shaking and I back off the gas a bit and then get back on the gas, there is no shaking for 5 to 10 second, then it shakes again. If I'm not on the gas or going down hill, no problem. Only when the engine is under a load. Cat problem? If so, how easy is it to change myself? Someone mentioned that it might be a clogged air filter. What do you think?
Thanks in advance!
BTW - after the clogged intake manifold was fixed they turned off the check engine light. I has not come back on.
Apr 19, 2009 at 3:40 PM
JYSPIRIT
Was the issue resolved finally? Could you please share the fix? I’m having the same problem with my 2005 odyssey, 204k miles. Vibration/shaking at speeds above 50mph after 20-30 minutes of running. Check engine came with P0420. Seem to be something with the exhaust system. Wondering whether to replace Bank1 catalytic converter. Thanks.
Jan 9, 2018 at 10:12 PM
CARADIODOC
  • 34,396 POSTS
This is a really old question, but some confusion should be cleared up. A plugged catalytic converter will not cause rough running or vibrations. The engine will run uncommonly smoothly, but with no power. It may backfire through the throttle body. You will hear a steady hiss from the tail pipe, not the normal "putt putt". Also a fault code related to catalytic converter efficiency refers to no change is taking place in the composition of the exhaust gas as it goes through it. That has nothing to do with being plugged. The readings from the front oxygen sensor switch between "rich" and "lean" about two times per second. If the converter is working, the readings from the rear oxygen sensor will switch perhaps once per minute or two. When the gas going out is the same as what went in, the rear sensor will start to switch at a faster and faster rate until eventually it matches that of the front sensor. That rear sensor switching rate is what the Engine Computer looks at to determine when the converter isn't cleaning up the exhaust gas. It can take days or weeks before that fault code sets again, unless the converter has failed completely.
Throughout this entire story, I never saw any indication the spark plugs were actually replaced. At the mileage listed, it would be a miracle if the original spark plugs were NOT causing a problem. This is like staring at a flat tire, and asking over and over why the vehicle steers funny. Every part of this description points to a misfire, and while there are other possible causes, it's silly to overlook the most obvious one.
Adding injector cleaner to the gas tank, or any other "mechanic-in-a-can" is not going to solve this. If that was the solution, we'd sell a can of that stuff every time someone had a failed spark plug. Even the cheapest gas you can find today has so many detergents and other additives. The stuff in the cans is just a highly-concentrated form of the same stuff. Think of washing your hands non-stop for weeks with soap and water, then you suddenly think they're going to become cleaner by using a wire brush with that soap.
The EGR system is being blamed unfairly for this. It's true a plugged passage will cause reduced flow, but that means there's less inert gas going into the cylinders and the engine will run better, with more power. The purpose of the EGR system is to dump a little spent exhaust gas into the cylinders to take up space so there's less room for fresh air and gas. That is never done at low speeds or idle, and not when higher power is needed as in when accelerating or under load. It only occurs when cruising with a low power demand. The only way the EGR system will cause rough running is if the valve sticks open at low speeds. That would result in too much flow. This fault code is for too little flow.
JYSPIRIT, you need to start a new question specific to your vehicle, and PLEASE be sure to list the engine size, mileage, and transmission type. Unlike other sites where anyone can chime in, here this becomes a private conversation between you and one or two experts who will stick with you to the end. This question is on our list of questions that have already received replies, and as such, none of the other experts will read it or see your addition. That won't get you the help you need and may be why you've been waiting so long for a reply. I only saw it because I was catching up on conversations where I thought I could learn something.
We need to know the engine size when looking up parts or wiring diagrams, and we look at the mileage when making judgments as to the most likely suspects, as in this question. That's why we appreciate it when that information is listed right up front. It's also helpful when you list as many details, observations, and clues in your original post as possible. Most of us are only here a few hours per day, and when the details have to be dragged out over numerous replies, it can take days or weeks to find the final solution. Things like whether the engine has to be warmed up, at what speeds this occurs, whether it changes during accelerating, coasting, or turning, etc., can be helpful clues.
Jan 10, 2018 at 8:44 AM
JYSPIRIT
Thank you CARADIODOC. I have posted a new thread at https://www.2carpros.com/questions/2005-honda-odyssey-204k-miles-shakes-at-speed-intermittent
Jan 10, 2018 at 11:35 AM
CARADIODOC
  • 34,396 POSTS
Dandy. I may pop in to see how you're doing, but other than the few things I know, I'm not an engine performance specialist. There are a few really good people here who are experts in this area.
Jan 10, 2018 at 12:37 PM
