2001 Honda Odyssey TRANSMISSION
2001 HONDA ODYSSEY
225,000 MILES • 6 CYL • FWD • AUTOMATIC
CAMARO1990
2001 HONDA ODYSSEY, JUST REPLACED TRANNY YEAR AND HALF AGO @ 170000 MILES. DRIVES GOOD ONCE CAR WARMS UP TO NORMAL TEMP IT STARTS SLIPPING GEARS UNTIL YOU JUST GOES TOTALLY BLANK. IF YOU LET CAR COOL OF BY SHUTTING IT OFF 15 TO 30 MINUTES IT DRIVES OK UNTIL IT GOES BAD AGAIN AFTER 10 MINUTES. FLUIDS ARE AT RIGHT LEVELS, NO LEAKS, STRONG ODOR FROM TRANSMISSION OIL DIP STICK. DOESNT SMELL BURNT. I NEED HELP. THANKS.
Oct 7, 2009 at 5:14 PM
CAMARO1990
[quote:3890a2cf71="CAMARO1990"]Transmission problem
2001 Honda Odyssey 6 cyl Front Wheel Drive Automatic 225000 miles
2001 HONDA ODYSSEY, JUST REPLACED TRANNY YEAR AND HALF AGO @ 170000 MILES. DRIVES GOOD ONCE CAR WARMS UP TO NORMAL TEMP IT STARTS SLIPPING GEARS UNTIL YOU JUST GOES TOTALLY BLANK. IF YOU LET CAR COOL OF BY SHUTTING IT OFF 15 TO 30 MINUTES IT DRIVES OK UNTIL IT GOES BAD AGAIN AFTER 10 MINUTES. FLUIDS ARE AT RIGHT LEVELS, NO LEAKS, STRONG ODOR FROM TRANSMISSION OIL DIP STICK. DOESNT SMELL BURNT. I NEED HELP. THANKS.[/quote:3890a2cf71]
Oct 7, 2009 at 5:15 PM
OHMUM
after reading forums on the Honda Odyssey's (1999-2004) they had some real issues with the transmission. The bands in the transmission gets hot and burns to the point where shavings plug things up internally. They had a class action lawsuit that pushed honda to give extended warranty's on these models for up to "I believe" 7years or 109K miles for replacement. My situation is the same as yours and I will be replacing the transmission with a used low mileage tranny that has at least the 6month warranty. The only bad thing is if the tranny goes bad, I will have to do the process over agian (just time I guess). I will let you know how it goes.
Aug 20, 2010 at 12:09 AM
