2001 Honda Odyssey DAYTIME RUNNING LIGHTS
117,000 MILES • 6 CYL • FWD • AUTOMATIC
NAVYBMC12
I have been having a problem with the right side daytime running light. It will just come on slightly. It seems like its missing a boost to run the bulb fort that mode. Full driving lights are fine and the left side works fine. I have replced the bulb checked the fuses and made sure the wires were plugged in snugly. Please help. I would hate to take it to the dealer and spend for such a small problem. Thank you.
Jan 13, 2008 at 12:50 AM
AHWEE09
Hi, I had almost the same problem as yours.. Did you get it fix? Any advise for me?
ahwee09
[quote:6ee8750a09="NAVYBMC12"]Electrical problem
2001 Honda Odyssey 6 cyl Front Wheel Drive Automatic 117000 miles
I have been having a problem with the right side daytime running light. It will just come on slightly. It seems like its missing a boost to run the bulb fort that mode. Full driving lights are fine and the left side works fine. I have replced the bulb checked the fuses and made sure the wires were plugged in snugly. Please help. I would hate to take it to the dealer and spend for such a small problem. Thank you.[/quote:6ee8750a09]
Oct 13, 2008 at 6:38 PM
KHLOW2008
  • 41,812 POSTS
Hi NAVYBMC12,
Ground the Red/White wire at DRL control unit terminal # 11 and if the headlight works correcty, the DRL control unit is faulty.
Nov 29, 2008 at 4:29 AM
