2001 Honda Odyssey Brake Noise
RAGHURAMR
I bought a used 2001 Honda Odyssey EX - it went through inspections etc recently and was registered.
After parking the van for over a few hours (early in the morning or later after I leave from work), when i start the car and I apply brakes, I hear a loud squeak. It happens a couple of times and then it disappears.
I had a mechanic look at the brake pads - he said they were good quality metallic pads, the rotors were in good shape, he could not find anything wrong.
Is this characteristic of metallic pads?
Sep 19, 2007 at 8:39 AM
MERLIN2021
  • 17,250 POSTS
Yes semi metalics are tough to quite...I use the more expensive ceramic pad, Look at your pads and see if the shims are on the pads, if so I would leave em alone!
Sep 19, 2007 at 9:34 AM
LOSTINMARS
  • 222 POSTS
did he actually pull the pads off? sounds like one, if not all, of the front pads has a crack in it. pretty common problem for most all hondas. in fact honda just circulated a bulletin on this. if they are cracked i would get a new set from honda (they're about $60) and new slide clips as well.
Sep 21, 2007 at 2:20 PM
