2001 Honda Odyssey
65,000 MILES • 6 CYL • FWD • AUTOMATIC
INSHAN
Hi Sir,
I'm experiencing a "clunk" or "thump" or "creaking" noise from the driver side front whenever I ran over a bump or accelerate briskly, I had both of my front coil springs replace ( they were broken) and I had an alignment performed a week after, do you have any idea or suggestion on what`s causing this noise. the mechanic re-check his work but cannot figured out this challenge. I`m not sure if this noise was there before the spring replacement or not.
Thanks so much.
Jun 21, 2008 at 5:42 PM
KHLOW2008
  • 41,812 POSTS
Hi Inshan,
Check the followings,
1. Engine mounts.
2. Lower arm bushes and ball joints.
3. Steering rack and tie rod ends.
4. Stabilizer end links.
Jun 21, 2008 at 6:38 PM
