2000 Honda Odyssey trouble codes and transmission
92,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVLEE4
i seldom drive this vehicle, so i have not felt the problem, but my daughter says the transmission is slipping very bad at times and the engine revves up.
i have checked the fluid and it is at the top mark and still looks red and smells like oil, not burned.
i also have a code reader as the check engine light comes on. the only problem it gives me is TCC CKT malfunction. i can clear the code, but the engine light came back on after about 100 miles.
David
Dec 20, 2008 at 9:05 AM
ZACKMAN
  • 4,202 POSTS
Can I have the actual code numbers?
Dec 23, 2008 at 2:09 PM
DAVLEE4
that is the problem, there is not a code. i have a code reader that i could look them up on, but it just lists it as mentioned. i have done some research on this van, and year model and have found a huge problem exists with the transmission. by the sound of many of the others writing, i did pretty well getting this much mileage without problems.
thanks,
David
Dec 23, 2008 at 3:23 PM
ZACKMAN
  • 4,202 POSTS
[quote] i can clear the code, but the engine light came back on after about 100 miles. [end quote]
I thought as the light comes back after 100 miles, you would have scanned the PCM again. TCC is torque converter clutch CKT low input/voltage. Usually this code has a "partner". It doesn't normally pop by itself.
Dec 24, 2008 at 1:19 PM
DAVLEE4
that is correct, i did rerun the diagnostic and got the same error again. that was the only error i got again.
i now have a new vehicle in the driveway to do away with the problem. thanks for trying to help me.
David
Dec 24, 2008 at 5:40 PM
