2000 Honda Odyssey Sutomatic Transmission
2000 HONDA ODYSSEY
168,500 MILES • 6 CYL • FWD • AUTOMATIC
HONDAODESSEY00
The AT for the van has been rebuilt. The mechanic now says that despite flushing the raditor of contaminants the coolant still has traces of metal debris that is entering the rebuilt transmission. He recommends fitting a supplemental cooler that will service the AT only and leave the existing radiator to cool the engine.
Is what he saying is true? Is this new addition required? Is the debris getting into the tranny through the coolant a fact? I am confused. This additional repair will cost more.
Apr 7, 2010 at 10:05 AM
KHLOW2008
  • 41,814 POSTS
Hi hondaodessey00,
When transmission fails, debris can get into the cooler and flushing would not clear them completely.
If debris are present, the recommendation is to replace it and that includes the radiator. Failure to do so can cause the trans to fail prematurely.
The repair shop has given you an alternative which is logical.
Apr 9, 2010 at 1:17 AM
