2000 Honda Odyssey Rotors
151,000 MILES • 6 CYL • FWD • AUTOMATIC
KAJAVED
How can i take off my front rotors. I took off the brake pads, caliper and caliper holder and i also managed to unscrew the two phillips screws which holds the disc. I tapped the disc with hammer so many times but all in vain. Any suggestion how can I take off my rotor. I also tried to put bolts where i unscrewed the philip screws. Please help me out in this......
May 22, 2009 at 3:42 PM
BMRFIXIT
  • 19,053 POSTS
Detach and remove two 6-mm disc retaining screws. Install two 8 x 1.25 x 12-mm bolts in existing holes. Alternately turn bolts 2 turns at a time until disc can be removed from hub.
Apr 21, 2021 at 6:51 AM
KAJAVED
hi
Thanks for your reply. I broke the bolts inside while I was trying to put the bolts in to pull out the rotors. Once the disc in off, removing broken bolts will be lot easier. Should I thread new holes or try to thread the previous hole where the broken bolts are?
BMRFIXIT
  • 19,053 POSTS
Should Fix old one if possible
