2000 Honda Odyssey rotor removal
140,000 MILES • 6 CYL • FWD • AUTOMATIC
LYELROW
Wheel is off, caliper and caliper bracket off... Does the Screw plate need to come out to remove rotor... or is the rotor just stuck... needing some hammer taps...
Jul 24, 2010 at 12:51 AM
MERLIN2021
  • 17,250 POSTS
1. Raise and support vehicle. Remove wheels. Remove caliper assembly, and suspend it using wire. See FRONT BRAKE CALIPER . Attach dial indicator to caliper mount .39" (10.0 mm) from disc outer edge. Check disc runout before removal. See appropriate table under DISC BRAKE SPECIFICATIONS . 2. Detach and remove two 6-mm disc retaining screws. Install two 8 x 1.25 x 12-mm bolts in existing holes. To prevent warpage, alternately turn bolts 2 turns at a time until disc can be removed from hub. 3. Clean disc of all rust, and inspect disc surfaces for cracks and grooves. Replace disc as necessary. To install, reverse removal procedure. Tighten retaining screws. Bleed hydraulic system (if necessary). See BLEEDING BRAKE SYSTEM . NOTE: On all models except S2000, an on-car brake lathe must be used to resurface front brake disc.
Apr 21, 2021 at 6:51 AM
MOLSONCANADIAN
  • 81 POSTS
yeah mine was really hard to get hard, my neighbor had to hammer hard!
MERLIN2021
  • 17,250 POSTS
Use a large ball peen if the screws strip the other way!
