2000 Honda Odyssey P740 TCC intermittent problem after long
145,000 MILES • 6 CYL • FWD • AUTOMATIC
CARPRO_TREX_EATER
My Odyssey gets the code P740 after a long drive (about 45 mins). When it happens, the check engine and TCS light comes automatically. After that the vehicle slips and kickback at low gears (especially moving from a stop signal). I have a scanner with me. If I erase the code and continue driving, the light and code appears in few miles and the problem remains the same.
If I erase the code and let the vehicle parked for more than 2 hours, everything returns to normal. I can drive it for short distance (less than 7 miles) for many days. No problem.
To me it looks like the transmission heats up and gets into some stuck state. Could it be a stuck "tcc solenoid". How much would it cost to fix it.
Any feedback will be helpful.
Oct 29, 2010 at 2:40 AM
KHLOW2008
  • 41,812 POSTS
Hi carpro_trex_eater,
Thank you for the donation.
The cost of repairs would depend on what needs to be replaced, solenoids or transmission itself.
Here are the diagnostic procedures.
DTC P0740: Problem in Lock-up Control System
NOTE:
• Keep replacement control solenoid valves on hand:
â—¦ Lock-up control solenoid valve assembly (lock-up control solenoid valve/shift control solenoid valve A assembly).
â—¦ A/T clutch pressure control solenoid valve A/B assembly.
1. Check whether the scan tool or the HDS indicates another code.
Does the scan tool or the HDS indicate another code?
YES: - Perform the Troubleshooting Flowchart for the indicated Code(s). Recheck for code P0740 after troubleshooting.
NO: - Go to step 2.
NOTE:
Do not continue with this troubleshooting until the causes of any other DTCs have been corrected.
2. Measure the line pressure
Is the line pressure within the service limit?
YES: - Go to step 3.
NO: - Replace the transmission.
Replace the Lock-up Control Solenoid Assembly set (lock-up control solenoid valve/shift control solenoid valve Assembly and the A/T clutch pressure control solenoid valve A/B assembly.
4. Clear the DTC with the scan tool or the HDS.
5. Using the scan tool, check to be sure that the engine coolant temperature is 176° F (80° C) or above.
6. Drive the vehicle under the same conditions as those indicated by the freeze data for more than 1 minute, or drive the vehicle at 55 mph (88 km/h) with TPS voltage 0.8 V for more than 1 minute.
7. Recheck for code P0740.
Does the scan tool or the HDS indicate code P0740?
YES: - Inspect the O-ring on the torque converter. If the O-ring is missing, replace the O-ring. If the O-ring is damaged or OK, replace the transmission and torque converter.
NO: - The system is OK at this time.
© 2008 Mitchell Repair Information Co., LLC.
Oct 29, 2010 at 5:18 AM
CARPRO_TREX_EATER
If it is the solenoid, how much would that repair work cost. Thanks.
Oct 31, 2010 at 10:45 AM
KHLOW2008
  • 41,812 POSTS
Book time for solenoid assy replacement is 0.5 hr.
Lock-up solenoid is listed at $ 389.11
Nov 1, 2010 at 3:14 AM
