2000 Honda Odyssey P1456
196,544 MILES • 6 CYL • FWD • AUTOMATIC
JAELYN09
Dtc 1456 what are the possible causes
Sep 14, 2009 at 2:00 AM
SAMBAL BADJAK
  • 20 POSTS
Probably - loose or improper seal on gas cap - wrong gas cap. If you left it loose after filling (at least 3 clicks tight) it may have triggered the light. If it was loose, but is now tight, it will turn itself off after several drive cycles.
Could be - a small leak in the evaporative system - part of the emissions system. If so, this will not repair itself and you will most likely be visiting the repair shop.
Sep 29, 2009 at 6:00 AM
