2000 Honda Odyssey High Output Overheat Message
159,000 MILES • 6 CYL • FWD • AUTOMATIC
OBEJUAN23
I was told that the error code that my Check Engine Light was on for was "High Output Overheat".
What does this really pertain to? The coolant levels appear to be normal. Is this in reference to the cooling system or maybe the exhaust system?
Jun 10, 2010 at 3:17 PM
HONDA TECH 1818
  • 536 POSTS
Do you know what code is it?
Jun 12, 2010 at 7:01 PM
OBEJUAN23
The shop that pulled the code, said that the verbage is all it shows, not acode #.
Jun 13, 2010 at 2:40 AM
HONDA TECH 1818
  • 536 POSTS
I need to know what code to diagnose the problem. If the CEL doesn't come back on after they reset it, the system is normal.
Jun 13, 2010 at 6:17 AM
