2000 Honda Odyssey dead battery, transmission acting up
2000 HONDA ODYSSEY
180,000 MILES • 6 CYL • FWD • AUTOMATIC
HALE128
When the van is running about 30 or 40 it runs and shifts great. Below 30 and the transmission acts weird on shifting. Battery was dead next morning, charged battery, shifting was great....until the battery was dead again. Took it to mechanic, he said that the codes (check engine light was on) said that the transmission was shot and something about the word ellyptical needed to be replaced. (I am assuming it that has something to to with the alternator). When the battery is charged, everything works great, yet the mechanic (got a little tuffy with me) states that the transmission is NO good.
Jul 31, 2008 at 3:47 AM
KHLOW2008
  • 41,814 POSTS
Hi hale128,
Test the charging system and make sure the voltage is between 13.5 to 14.5. Test battery to see if it is holding charge well. Worry about the trans later.
Get a second opinion if problem persists after confirming charging and battery is ok
Aug 16, 2008 at 6:26 AM
