hi, i have a check light on my van, so the computer needs resetting. how do i change this?
Sep 4, 2009 at 3:16 AM
HONDA TECH 1818
✓Experienced Mechanic
Did you fixed the problem, or you just want to clear the check engine light, you can disconnect the negative battery terminal for 10 seconds and reconnect or you can clear it with a code scanner.
If there is a problem with your engine the CEL will come back on.
Oct 18, 2009 at 4:33 PM
KLEONLOVE2008
MEMBER
1 POST
2000 Honda Odyssey . The coolant temperature gauge going up is ignition turn on
Oct 16, 2020 at 12:28 AM
Please post your new question here, you must be logged in.
